Hi All
I have some sensor from Home Assistant. Is it possible to have the icon change when the value change. now its only change from off to on, Icon stay the same. I use the nice QuickApp create by rangee . thx Martin
/monthly_2021_12/image.png.49207ecfda653177a7588112a78c03b6.png" />
Hello Martin,
I didn't have a answer on your question.
But I have a question for you how you imported sensor from home assistant?
33 minutes ago, Fireman said:
Hello Martin,
AFAIR we have 3 solutions an no 4.
solution with HASS->Hc2 (also works with hc3 with some limitations) by @petergebruers
solution by @hater
solution by @vid_ua
and solution by @rangee
Edited by 10der
