i do not know but i woundn't  this options
so!
[SAVE]
/monthly_2021_12/image.png.3b4a9c10485e1946a48ab790f59a65aa.png" />
After refreshing the parameter value is still on 0.1?
Which devices is it? It is probably one of our switches, but which one?
    yep!
    Quote
    That interesting.
    That is in theory old 2x1.5 Switch but in version 3.94 which do not exists and never existed ? - highest know version is 2.2.
    Could you try reconfiguring this module?
    Are those relays really turns off after 0.1 or device is working normally?
    22 hours ago, m.roszak said:
    That interesting.
    after reset = all 0 (zero)
    after reset to default
    probably device is dead.
    Now device have a correct version.
    We will check it out (if we can reproduce this one).
    I will keep you posted.
    I have included the same Switch to my test system and everything is working as expected.
    If this is not a problem I would like to take a look directly in your configuration.
    PM me if you will have some spare time :)
    Michał
    Sir, I wouldn't spare you busy time.
    90% of devices in my home are now Zigbee. dead device (read as wrong works) in HC3 it's the step for moving yet another device to ZigBee.
    thank you for response!
    I hope that you will be happy with Zigbee - choose wisely end-devices and everything will be ok :)
