QA onInit query
when ever i save a qa it seems to run the oninit twice once on the presave and then again on the save, am i doing something wrong by leaving stuff in the memory which i should be clearing first?
[30.12.2021] [15:28:33] [DEBUG] [QUICKAPP523]: onInit
[30.12.2021] [15:28:33] [DEBUG] [QUICKAPP523]: checking --this was what i was removing on this save
7 answers to this question
what do you mean with presave?
    to test it if i do a print("something") save and then remove the print comment often i will notice that the print will come up and then it will oninit again and not show it.
    Is it QA that consists of several files?
    it does not seem to make a difference if there is just one main file or other files too, i seem to be getting it on both.
    Can you post  a minimal QA that has this behaviour? A reason could  be that your QA is failing silently after a restart that causes the second restart...
    here is qa i am in the process of building which does this
    [02.01.2022] [13:03:42] [DEBUG] [QUICKAPP478]: Sonos Variable is 192.168.1.212
    [02.01.2022] [13:03:42] [DEBUG] [QUICKAPP478]: Song Name Variable is //nas/music/LeChaim Tish/Lail Shabbos/06 Koh Echsoif.mp3
    [02.01.2022] [13:03:42] [DEBUG] [QUICKAPP478]: Music Type Variable is Motzei
    [02.01.2022] [13:03:42] [DEBUG] [QUICKAPP478]: Music Volume is 10
    [02.01.2022] [13:03:42] [DEBUG] [QUICKAPP478]: onInit
    Edited by Jay Ess
    a new QA does this on save
    [02.01.2022] [13:12:11] [DEBUG] [QUICKAPP460]: onInit
    [02.01.2022] [13:12:12] [DEBUG] [QUICKAPP460]: onInit
    the qa has this in it
    function QuickApp:onInit()
        self:debug("onInit")
