Hello everyone and Happy New Year.
I struggling with the quick app feature. Basically, I just try to create two buttons in Fibaro HC3.
When pressing the button it should send following command: http://192.168.3.5/api/app/com.internet/RolKeukenNeer
When pressing the other button, the command should be as follow: http://192.168.3.5/api/app/com.internet/RolKeukenOp
I did use several manuals, but don't see to get this work (even not create a button. Can someone help me please ?
can you show your code for "broken solution" :)
    Hi. I have no code yet, since I don't understand how I need to create the buttons.
    Like this ?
    Thanks for the explanation to create the buttons. The command "http://192.168.3.5/api/app/com.internet/RolKeukenNeer" do I need to put this instead of 'ID' ?
    The buttons are created. But don't see where I put the command "http://192.168.3.5/api/app/com.internet/RolKeukenNeer"
    I did do the below, but this seems to be wrong. Any help appreciated
    Anyone who could guide me in the right direction please ?
    I have the 2 buttons now, but what need to be created in order to send the command "http://192.168.3.5/api/app/com.internet/RolKeukenNeer".
    (The http line is actually a command to send information to a Homey controller).
    Is there something extra I need to create ?
    @Ypolit
    Here you will find documentation on how a QuickApp works and how to create them.
    Only when you understand the basics can you ask meaningful questions.
    I have painstakingly created my own QAs using this documentation as well as spying on how @SmartHomeEddy has done :-)
