switch on light for x minutes and if no movement switch off
I have a scene which is triggered by a sensor on movement does this. while it all works nicely the issue i have is if the timer is interupupted the scene starts counting again and this throws an error as this:
[02.01.2022] [17:12:49] [ERROR] [SCENE109]:
What would be a better way to run this kind of countdown which would allow a restart from the begining without throwing this error?
for k,i in ipairs(GroupToiletOn) do
    if fibaro.getValue(i, "state") == false then
        fibaro.call(i, "turnOn")
--run timer for light
safeTime = 0
maxTime = SwitchOffImeDelay*60
while safeTime < maxTime do
    fibaro.sleep(1000)
    safeTime = safeTime + 1
    --fibaro.debug("Scene109", "Timer for Toilet light - "..safeTime.." of "..maxTime.." seconds.")
--switch off light
for k,i in ipairs(GroupToiletOff) do
    if fibaro.getValue(i, "state") == true then
        fibaro.call(i, "turnOff")
20 answers to this question
I don’t think this is the complete scene ?
I don't understand?
I don't  think you use that pir for security so..
why not set pir save time to 4 min (or something else)
If pir is breached -> light on  if pir is save -> light off
What do you meant by timer interrupted? Is the scene triggered again? if so the previous scene instance is killed and the new instance is starting to run... and it should be like that.
Please post entire scene's code and trigger conditions
    Trigger:
      conditions = { {
          id = 498,
          isTrigger = true,
          operator = "==",
          property = "value",
          type = "device",
          value = true
      operator = "any"
    Rules:
    --Set Locals
    local jT = json.decode(fibaro.getGlobalVariable("jHomeTable"))
    local currentDate = os.date("*t")
    local currentTime = os.date("%H:%M")
    local SummerTime = currentDate.isdst
    local HumidityDeviceId = jT.Toilet.Humidity
    local MotionSensorDeviceId = jT.Toilet.MotionSensor
    local LightLevelSensor = jT.Toilet.LightSensor
    local ToiletLight = jT.Toilet.Light --155
    local ToiletFan = jT.Toilet.Fan
    local ToiletLightState = fibaro.getValue(ToiletLight, "state")
    local HumidityDeviceLevel = fibaro.getValue(HumidityDeviceId, "value")
    local MotionSensorDeviceStatus = fibaro.getValue(MotionSensorDeviceId, "value")
    local ShabbosVariable = fibaro.getGlobalVariable("shabbos")
    local PlagHaminchaVariable = fibaro.getGlobalVariable("plagHamincha")
    local ErevChagVariable = fibaro.getGlobalVariable("erevChag")
    local LuxLevelVariable = tonumber(fibaro.getGlobalVariable("lightLevel"))
    local SwitchOffImeDelay = 5
    local SwitchOffImeDelayFan = 5
    local NightModeStart = "23:00"
    local NightModeEnd = "08:00"
    --Set Lights In To Group And Change Depending On Time
    local GroupToiletOn = {ToiletLight,ToiletFan}
    local GroupToiletOff = {ToiletLight}
    local GroupToiletFan = {ToiletFan}
    --Start Light Control Only run if it not Shabbos
    if (SummerTime == true and (currentDate.wday == 6 or ErevChagVariable == "true") and currentTime >= PlagHaminchaVariable) or ShabbosVariable == "true" then
        --fibaro.debug("Scene109", "Condition Day or Time")
        return
    --Start timer to switch on light and then switch off
    safeTime = 0
        fibaro.sleep(1000)
    --switch off light
    --run timer for fan
    safeTime = 0
    maxTime = SwitchOffImeDelayFan*60
        fibaro.sleep(1000)
        --fibaro.debug("Scene109", "Timer for Toilet fan - "..safeTime.." of "..maxTime.." seconds.")
    for k,i in ipairs(GroupToiletFan) do
    I understand that it is working as expected by a new scene killing the old running one, which causes a debug error, while it works it does not seem elegant and was looking for a better way to do this.
    But do you have "Allow to restart a running scene: " setting on "No" ?
    setting is Yes, as if there is movement within the time span i want the timer to start again
    Should be "No".
    You want the timer to start again, but not the whole scene.
    There is a 200+ posts thread on this topic
    how can i trigger the motion remotely to test it? other then running the scene?
    You want to  fake the sensor getting breached so your  scene is triggered?
    I would suggest that you move your code over to a QA and use some of the trigger/events libraries to get triggers.
    There you can also post "fake" triggers (like a device being breached) to test your code and logic.
    thank you am trying to work out your timeout code on the scene above but cant get the logic of it, would you be able to help please. this is what i have so far.
    --Set Locals
    --local secs = SwitchOffImeDelay * 60
    local sleepTime = 1
        return
    print(secs,fibaro.getValue(MotionSensorDeviceId,'value'))
    --loopUntil(<loop function>,<end function>,<time in Xseconds>)
    function loopUntil(fun,cont,secs)
    print("function",fun,cont,secs)
        local function loop()
            if not fun() then
                fibaro.setTimeout(1000*secs,loop)
            else
                if cont then cont() end
            print("Turn On Light")
            --fibaro.call(i, "turnOn")
    local safeTime = 0
    local mAxTime = SwitchOffImeDelay * 60
    print("Line 57",mAxTime)
    loopUntil(function()                                     -- Loop function
            if safeTime >= maxTime then
                print("safe time is greater")
                return true
            print("We should be checking here")
            safeTime=safeTime+sleepTime                   -- count up safeTime
            fibaro.debug("Counting up safeTime ",safeTime,maxTime)
            if fibaro.getValue(MotionSensorDeviceId,'value') > '0' then -- motion breached
                safeTime=0                                 -- reset safeTime
                fibaro.debug("Reset")
        end,
        function()                                     -- Stuff to do after loop finished
            fibaro.debug("Turning off")
            --fibaro.call(light,’turnOff’)
        end,
        sleepTime                                      -- Time to sleep between loops (in seconds)
    fibaro.alert("email", {emailUser}, "Updating Shabbos Time<br>This email is generated from Scene 98.")
    safeTime = 0
        fibaro.sleep(1000)
    --switch off light
            --fibaro.call(i, "turnOff")
    --run timer for fan
    safeTime = 0
        fibaro.sleep(1000)
    LOL not completly stupid just trying to get c# module to work with ms access and some thml java at the time as doing this coding and it is frying my brain, too much different lang floating around my head LOL
    thank you for any help provided.
    Edited by Jay Ess
    This works ok. You had a capital A in maxTime and you compared the value from the motion sensor with > '0', but a binary sensor returns true/false
    However, I wouldn't recommend this code - you should try the "abstracted code" later in the referred thread.
    I see  that you also would like to check other stuff, fans etc.
    Then you need to either split it up into multiple  scenes or move over to a QA with an asynchronous event  mechanism.
    lol was lookinjg through the thread looking for a later version of it but didnt manage to se it can you point me to it please?
    am i correct that settimout is better then sleep?
    isON() and ON() can then easily be extended to check multiple sensors or turn on multiple lights etc.
    thank you, so it has gone back to using sleep?
    thank you for your help.
    in a nutshell what i need to change is this code, which will loop as long as there is motion and switch off the allow scene to run more then once,
        fibaro.sleep(sleepTime * 1000)
        safeTime = safeTime + sleepTime
        print("Counting safe time %d para maxTime %d",safeTime,maxTime)
        if fibaro.getValue(MotionSensorDeviceId, "state") == true then
            print("we are checking the state of the motion sensor here")
            safeTime = 0
    what is the benifit of running this in a qa? and how would i trigger it to run based on the motion?
    this is my scene now which seems to be working - if i understand correctly then timeout is less system resource then why not use timeout instead of sleep?
    --Set Locals
    local safeTime = 0
    local sleepTime = 10
    local maxTime = SwitchOffImeDelay * 60
        return
        fibaro.sleep(1000*sleepTime)
        if fibaro.getValue(MotionSensorDeviceId, "value") == true then
            safeTime = 0
        print("Counter for light",safeTime,"Motion",fibaro.getValue(MotionSensorDeviceId, "value"))
    if ShabbosVariable == "false" then
    --run timer for fan
    safeTime = 0
        fibaro.sleep(1000)
    Hi there. I want to ask for your help. I’m using the attached scene to control the lights which works great, but I’d like it to turn off the brightness to 20% for 10 seconds before turning it completely off. If there’s no more movement then the lamp should turn off and if there is movement it should go back back to 99%. Thanks in advance.
    local light = 52
    local motion1 = 55
    local maxTime = 3*60
    local sleepTime = 5
    fibaro.debug("","Turning on to 99")
    fibaro.call(light,"setValue","99")
    local safeTime = 0
    fibaro.sleep(sleepTime*1000)
    fibaro.debug("","Counting up safeTime ",
    safeTime,"to maxTime ",maxTime)
    if
    fibaro.getValue(motion1,"value")
    then
    safeTime=0
    fibaro.debug("","Reset")
    fibaro.debug("","Turning off")
    fibaro.call(light,"turnOff")
    jgab@ Thank you very much :)
