Hi All,
I Installed the update around 5:30pm today.
Backup, download and install Seemed to go ok, but around 6pm it got to the rebooting stage and has been stuck there for around an hour now.
On the unit there are seven solid lights on the right, the eighth light on the left (has a sun symbol?) is blinking slowly.
Is this normal?
Should I be doing something about it, or just leave it to sort itself out?
Phil
    After 2 hours 45 minutes, still no change, rebooting please wait!
    I powered down the HC3 and restarted, within a few minutes it was awake and shows it has updated to the new software.
    Notification showed that there was a problem rebooting and system restarted.
    Everything seems ok.
    Does anyone know if there is anything I should do to stop this happening again?
    Phil
    Know issue, it happens time to time....  there is nothing you can do
    When I updated I had constant issues after days of this I rolled back to previous version. I am amazed at the lack of Quality Control Fibaro seems to have and checking moments ago still no new release is available to address issues.
    What issues did you have?
