pandrade 0
I have a pergola which is operated through Somfy motors, and controlled with a remote (there is no wired switch). The wireless receiver is mounted within the pergola itself, and wired to the motor. I am interested in being able to control this motor through my home automation platform, and was thinking to place a RS3 between the wireless receiver and the motor. The wiring is something like the below. So I would connect the UP/DOWN wires from the receiver to the S1/S2 inputs, and connect the outputs from the RS3 to the motor, configuring as toggle switch (not momentary). This way I should (I assume) keep normal remote functionality, with the addition of being able to control through RS3 as well. Has anyone seen a similar case? Any reason why this wouldn't work?
/monthly_2022_01/image.png.f18d5ec386adafa826bae3a4b0762309.png" />3 answers to this question
