hi @m.roszak Michal!
why my QA can restart silently?
Ok if i can see critical errors in log but only facts of restart
05-01 12:02:1 warning QUICKAPP2046: Ring deviceID 2685513 started.
05-01 12:02:0 warning QUICKAPP2046: use exists hardware_id.
05-01 12:02:0 warning QUICKAPP2046: Starting...
05-01 11:36:1 warning QUICKAPP2046: Ring deviceID 2685513 started.
05-01 11:36:0 warning QUICKAPP2046: use exists hardware_id.
05-01 11:36:0 warning QUICKAPP2046: Starting...
05-01 10:11:1 warning QUICKAPP2046: Ring deviceID 2685513 started.
05-01 10:11:0 warning QUICKAPP2046: use exists hardware_id.
05-01 10:11:0 warning QUICKAPP2046: Starting...
05-01 8:23:1 warning QUICKAPP2046: Ring deviceID 2685513 started.
05-01 8:23:0 warning QUICKAPP2046: use exists hardware_id.
05-01 8:23:0 warning QUICKAPP2046: Starting...
05-01 6:13:1 warning QUICKAPP2046: Ring deviceID 2685513 started.
05-01 6:13:0 warning QUICKAPP2046: use exists hardware_id.
05-01 6:13:0 warning QUICKAPP2046: Starting...
05-01 4:23:1 warning QUICKAPP2046: Ring deviceID 2685513 started.
05-01 4:23:0 warning QUICKAPP2046: use exists hardware_id.
05-01 4:23:0 warning QUICKAPP2046: Starting...
05-01 2:56:1 warning QUICKAPP2046: Ring deviceID 2685513 started.
05-01 2:56:0 warning QUICKAPP2046: use exists hardware_id.
05-01 2:56:0 warning QUICKAPP2046: Starting...
05-01 2:31:1 warning QUICKAPP2046: Ring deviceID 2685513 started.
05-01 2:31:0 warning QUICKAPP2046: use exists hardware_id.
05-01 2:31:0 warning QUICKAPP2046: Starting...
05-01 1:12:1 warning QUICKAPP2046: Ring deviceID 2685513 started.
05-01 1:12:0 warning QUICKAPP2046: use exists hardware_id.
Do you update some fields (api.put "/devices/ID",{...})) of the QuickApp struct? Besides 'properties' it causes a restart.
Do you update/write/delete a file in the QuickApp with the api? also causes restart.
    /monthly_2022_01/image.png.254a871971c5247e8e06120ae9a422da.png" />
    also QA hasn't any additional file(s)
    ...so then the question is - what strange things do you do in your QA? ;-)
    It could still be bug in your code followed by a crash and a silent restart - but I haven't seen those in a while. If the QA crashes in the main thread it seems to always report - if it crash in a thread (setTimeout) it's still a silent crash but don't cause QA restart... it seems like.
    setTimeout
     setTimeout
      setTimeout
       setTimeout
    :) yep.
    i can rewrite this stairs via events ideology what you preach :) but not sure what it fix the root cause issue.
    QA attahced.
    Edited by 10der
    Ha!, I managed to create a silent crash in the main thread...
    A http success handler that dies inside another http success handler (or error handler) and the other handler then dies - gives me a silent crash and restart. Remove the call to g() or just a single handler, and we get an error message.
    So, when the first success handler dies there seems to be no place for the second handler to fail to - and we just get a silent restart
    I guess this can be a fairly common error when people nest their httpcalls do deal with the asynchronous nature of HTTPClient's callbacks.
    It would be easier if they let us use coroutines so we could have a "synchronous" version of
    that would allow users to make sequential request... less errors, less upset home coders, and less complaints to Fibaro...
    So, you have a bug in your code and the http code is bad at handle some errors in its success/error handlers....
    Solution wrap your success/error handlers in pcall.
    My fibaroExtra.lua library has a compatible net.HTTPClient that does it for you.
    Jan.
    Morning
    part#1
    part#2
    @jgabJan should i wrap  setTimeout as well?
    Eh, lot of stuff going on at the same time there....
    What if you just plop in this replacement of net.HTTPClient and code like before?
    So, the solution is for Fibaro to protect the success/error handlers with pcall so that users get reasonable error messages.
    The simplest is just to patch the HTTPClient (and there may be issues with other net.* callback functions)
    It would be more efficient to patch the original net.HTTPClient as there would be no need to copy the ops parameters.
    Running this we get an error message instead of a silent restart.
    ...also while we wait for Fibaro to improve their framework we can always collect "patches" like this in a quickapp file we include in our QuickApp projects.
    It's also a good idea to include a patched setTimeout/setInterval to also report errors (they are also silent).
    ...and maybe not update QA properties that don't exists etc etc.
    ...or you can use my
    file that implements all this + other "missing" functions for QAs....
    I think I found the MVP for silent restarts
    I would at least expect a
    [08.01.2022] [11:25:01] [ERROR] [QUICKAPP806]: main.lua:3:
    It's kind of interesting that
    which also causes an error (foo not defined) does not create a restart.
    yup! already tested before you public here
    its very strange
    The last one is of course related to the setTimeout doesn't log errors in the called function
    its very strange
    My current thinking is that it's some luabind errors that slip by.
    setTimeout(error,1) restarts but setTimeout(__fibaroSleep,1) does not
    Nothing in "pure Lua" seems to cause restart.
