sjstrobl 2
I would like to use Fibaro Dimmer 2 to dimm a 24V LED stripe behind a 24V / 100W transformator.
Can anyone recommend a 80-100W 24V LED trafo that is known to work with Fibaro Dimmer 2?
Today, I'm using this trafo (
) which works fine with my classical Triac Dimmer, but when connecting Fibaro Dimmer 2 the auto-calibration fails (red LED flashed), in best case I'm able to switch the LED on/off without any dimming...Thanks!
Stefan
8 answers to this question
