check if qa variable exists and if not create it
how do i create a new qa (self) variable fromw ithin a qa please?
12 answers to this question
api.post("/globalVariables",{name="myVar", value="ok",isEnum=false, readOnly=false})
Ah, you asked for a QA variable....
You don't need to create them - just self:setVariable("Test",55) will create test if it doesn't exist.
and unfortunately, with Fibaro's wisdom they let self:getVariable("test") return "" if the variable doesn't exists (but you get a warning in the console)
After:
var = self:getVariable("var")
I do:
if var == "" or var == nil then
  var = “1234”
  self:setVariable("var",var)
    when i run this in a qa i get this error: setup.lua:10: attempt to index a nil value (global 'self')
    this is my function which i am trying to setup:
    function setQAVariables()
        local CornerVariableName = "shabbosLightCorner"
        local DovidVariableName = "shabbosLightDovid"
        local RifkaVariableName = "shabbosLightRifka"
        local ShanaVariableName = "shabbosLightShana"
        local tb={CornerVariableName,DovidVariableName,RifkaVariableName,ShanaVariableName}
        for k,v in pairs(tb)do
            print(v)
            var = self:getVariable(v)
                self:setVariable(v, "true")
    what am i doing wrong?
    You can only use self inside a
    function QuickApp:<name>(….)
    thank you fixed
    if i have a function fn(a,p)
    return a*p
    i now want to set a qa variable how do i do that please?
    i cant use self:setVariable as the function is not a QUickApp:function?
    return a*p
    sorry thought i had understood what you had written but i try it, i cant get it to work and throws me errors.
    i am trying to get a qa variable.
    Edited by Jay Ess
    is there a way of getting the last update of the qa variable?
    You mean when it was updated? Not really for an individual quickAppVariable.
    You can get the last time any quickAppVariable was updated
    local sLastUpdateTime = select(2,fibaro.get(self.id,'quickAppVariables')) this does the same with out having to define the _variable correct?
