No date for 2022??
I would change the time on my HC2 as it usually lags behind after a while. When I had to set the date and time manually, I noticed that it was not possible to select 2022 in the drop-down list, but it stopped at 2021. Now the Yubii app has stopped working and this after it has become 2022. Is it just me who has this problem? I on version 4.620.
4 answers to this question
    Thank you very much, it did the trick ?
    Hi all,
    I found another solution to that issue - just use Firefox Web Developer Tools (WDT0) to edit the interface and add needed year:
    Open Fibaro Location Settings in FF, and turn on WDT (Settings -> More Tools). With the tool
    /monthly_2022_01/image.png.e3830f30734ec22a70b7e013b1c5d4d4.png" /> select the year dropdown list. You will see this line highlighted:
    Click on three dots - the html code will expand, reviling the year list. Then right-click on the list, select "Edit as HTML" and add the year you want:
    Go back to the interface:
    There you go!
    Your welcome!
    Piotr
    Edited by Piotr P.
    Path to WDT corrected
    Anyone, please also post here the VD for NTP time update?
    There is a colleague who has this VD on a French site, but I do not need another account just to download single VD.
    Thank you,
    Piotr
