Hello everyone
May I have some questions regarding Child devices.
I have read JGAB's tutorial on this scope, and its very useful, but there are some questions still arising in my mind, what i couldn't get answered.
Question1:
What is the purpose of a child devices? Why do we use them? I can't explain to myself why would I mess around with all those initializations and
definitions if it seems to me that everything can be solved right within the parent QA.
Question 2:
On other hand i can see some situations when it might become handy if it worked. Like the picture attached, It is a thermostat with linked devices..
Now the first thing is, i don't know if these devices are child devices, or are linked devices, or are both of them?
Question 3:
If in the picture atteched we see child devices. Are they the same "CHILD" devices as you are describing in your tutorial ? If so, how can we make an existing
device become a child device of our QA? Or am I completely misunderstood this topic?
Can we add an existing real device as a child to a QA, or a CHILD device can be only a QA made child device, kinda virtual one?
i have device. for example this device is old android 5.0 device with Zipatile FW.
i do not use Zipato and Zipatile software at all but this device can pass to me
(1)* the current temp
(2)* the current hum
(3)* the current lux
(4)* the current noice
(5)* the current motion
(6)* Power On state
so. now for you.
you like when you develop 6 (six) separated QA's instead on develop all code in one single QA what can create and control all 6 (six) child devices
PS:
after screenshot i forgot about but
ton keys, cuz device can pass to me pressing on the screen some buttons
Edited by 10der
    Thanks for your answer,
    I understand what you say..ofcourse its better to handle all those 6 fetures in one QA..but i asked, why you need child devices for this..Why not jsut a normal QA.?  You can easily get all 6 features from 1 QA without having any child device..
    And there is my major question..How can you make an exisiting device become a child device of a QA..this is what is far beyond my current comprehension..
    no u can't. but you can wrap exists real device to QA
    still do not catch your question.
    again. if you hate child :) please crate 6 (six) QA with temp hum etc etc so on so on
    another trying to catch your question
    how i can draw temp hum etc etc so on so on on single title of QA? you can draw only temp / hum / lux  etc
    yes you can draw anything on expanded panel but... i wanna to see all and at once
    All those 22C°, 2 C°, 46 °C etc etc are coming from that one device right?
    And it is a real device Zipato right?
    Then how did you make CHILD of them..You said its not possible...
    Man i can't get it...
    I have made a zone controller QA which can user use in YUBII for PLAN adjusting and for extended time selection for ovveride..but i never used any child device context...
    In your example, you are using your Zipato as child device of a QA ??? You said its not possible...
    Here above forexample the Current temperature is coming from device 789. The panel operation mode (Auto Off Cool Heat) is coming from a Panel Climate Zone with ID 32...so these are two different devices in my QA.
    How can I make forexample a child device from my Temperature sensor 789 ?
    Is this a good example where i could use Child device or this is not the case ?
    no u can't
    dixi
    it's NOT real Zwave device!
    So you created a QA, where you are getting all these data from some other real device by using API calls i guess ?
    Then you cretated separate child devices for all these data types inside that QA ?
    API calls i guess
    mqtt but it do not care right now
    answer = yes
    3 hours ago, Neo Andersson said:
    Hello everyone
    Question1:
    Question 2:
    Question 3:
    Q1:
    to have source code in one place, less memory consumption, you don't need to create mechanism how to exchange data between your QAs, ...
    Q2: example of QA child devices - how it looks (my Evohome QA)
    Q3:
    it's not possible to change existing QA to child device. You have to create them from your parent QA device (example is in jgab code or in fibaro's tutorials)
    example of parent QA device - you have to write logic how to create child devices, how to refresh them etc.
    Edited by petrkl12
    Hello Neo Andersson,
    i can't make a contribution to your child-questions, but i would ask you to share your zone-controller QA.
    It looks good, i am searching for such QA.
    Thank you in advance.
