Fibaro - I express total dissatisfaction with the stability of the fibaro system ....
I use HC3+ zwave3 + 67 devices, no scenes, all controlled by EventRunner4.
A few days ago, half of the devices fell out of nowhere, half of the devices are not available and do not communicate. It is neither possible to remove them, only via force remove, nor to add them even after resetting the device to the production stop / e.g. hold the fibaro head in the yellow stripe and then twist and release./After removal do not go back to the fibaro system.
I didn't make any changes, interventions or adjustments, I did it myself.
It does not help restart, does not help to load an older backup, does not help save to a backup and load.
It's a pity, for the third time Fibaro disappointed me that the system crashed for no reason.
I am thinking strongly about moving to something else. And all my other customers and friends I manage with will pass with me. Fibar will have fewer customers and they deserve it. Stability in "fucked", zigbee in "fucked", 433Mhz in "fucked" ......
too much started "F" in text :)
btw. (not in defense)
please bought Zniffer, please.
67 devices is critical as for me. you should clear understand what and where issues in your Zwave network.
ok you will moving to another controller (approve! :D) but you will still with closing eyes what happened in your zwave network.
WBR, O.
    I don't really want to move to another system unless there is another way out.
    I was satisfied with the Fibaro + EventRunner system, only if there were no such crashes that everything was running, and suddenly without any change or intervention the network is "ko", the devices do not respond and look like they are not connected to the network.
    I would like to find out what happened in the system but how? Fibaro didn't release any tools for that. I don't even know which points my devices within the mash network are actually connecting to. Somewhere I even caught the information that in the zwave3 system they only connect to the central unit and not to other devices within the network / sockets, dimmers, switches, etc. /.
    So please advise how to find out what caused the error, or I'll give you remote access and try to figure it out.
    Fibaro has been like this for over 10 years so don't expect them to change.
    Promised features not there so you take upgrade and it all breaks.
    My HC3 is/was running for several months like a charm!>>>Thanks to Event Runner 4!!!!!!!!!!
    Zwave 3 I didt tuch because its not already mature and its missing several devices.
    //Sjakie
    as i can understand you miss me ?
    so again.
    please buy ZNIFFER
    please read this post
    Ok, thanks for the info. I'm going to study.
    Please advise, should I use the old z-wave engine on HC3 or rather the new z-wave3?
    Edited by budu
    if you switch hc3 on new zw3 you will must re-include all devices, but if you already on zw3... you guinea-pig in Fibaro lab :)
    Edited by 10der
    Yep, it is in beta and has several limitations. If I read the title of your post, I don't think you should run Zwave3. Go for the more reliable solution (but you have to re-install all your devices).
    since I have been running on z-wave 3 at the same time since it was made available, I did a complete reset then and added all the devices again. Everything was running fine until half of the net suddenly dropped out
    /monthly_2022_01/image.png.68fc73e8fc661ed69c35b30eb389a000.png" />
    You were lucky :-)
    You were unlucky ;-)
    lucky -/- unlucky = neutral ?
    You went the path of the zwave3 beta, so it is not likely you will go back (with re-install, etc)
    But there are definitely limitations on the zwave3 engine. For example see a status november 2021:
    On 11/18/2021 at 4:20 PM, tinman said:
    ... on zwave 3.0 there is currently no option availabe to update mesh, one have to:
    - get z-wave stick and PC Controller sw
    - include that stick (let it near your HC3, to avoid false positive routing), as device, to your HC3x
    - click any mains powered device and click node infoand get version
    - from IMA panel do redicovery and maybe netowrk health
    - exclude zwave stick
    - reboot HC3
    So I can understand your feelings with Fibaro, but I also think it is part of the "beta thing".
    I have no clue but did you revert back to the time it was running?  Probally you already did.
    //Sjakie
    Did you contacted support?
    I am pretty sure that one of our developers will take a look.
    As said before in this topic, engine 3.0 is in beta phase - you have decided to go for it, ok.
    Just remember that its a beta, we would really like to take a look at your configuration to help us improve it.
    That is probably a one part of using beta features - giving a feedback.
    So, I see two options - contact support and arrange remote access and allow us to take a look, or - start from the scratch and use Z-Wave 2.0.
    Michał
    @budu
    Could you check in the settings
    16 - zwave, then open the tab "smart start"
    When my zwave devices get disconnected, i get a protocol error there. (i have this every few days)
    Switching a few time between smart start, and the firmware update tab. Restarts the service.
    And will bring back the connection with my zwave devices.
    I have it this way, I don't see any protocol there.
    8 hours ago, m.roszak said:
    Kontaktovali ste podporu?
    Som si celkom istý, že sa na to pozrie jeden z našich vývojárov.
    Ako už bolo povedané v tejto téme, engine 3.0 je vo fáze beta - rozhodli ste sa ísť do toho, ok.
    Nezabudnite, že ide o beta verziu, naozaj by sme sa chceli pozrieť na vašu konfiguráciu, aby sme ju mohli zlepšiť.
    To je pravdepodobne jedna časť používania beta funkcií - poskytovanie spätnej väzby.
    Vidím teda dve možnosti – kontaktovať podporu a dohodnúť si vzdialený prístup a umožniť nám sa na to pozrieť, alebo – začať od nuly a použiť Z-Wave 2.0.
    S pozdravom,
    Michal
    Well thank you. I will contact the support, I am interested in repairing and operating it.
    Contact support here???????
    /monthly_2022_01/image.png.00a248514744dbc803d8bc858efc970b.png" />
    Edited by budu
    Well, then it seems i am the only one with the protocol error ;/
    I am good at doing stuff nobody else can....lol
    Good luck man, i hope you will solve your problem with the hc3!
    Hi. So after consulting with the support it looks like a hw glitch, left the z-wave chip in home center3.
    Reset to factory settings and no device can be added in either old zwave or zwave3. So claim the device.
    Edited by budu
