GilP 0
Hello everyone,
i'm new with Fibaro product. I encounter a problem when i'm trying to add a FGBS-222 (fw 5.2) module to ZwaveJs2Mqtt (6.3.0) through Aeotec ZWA010 Z-Stick 7 GEN7 (fw 7.15)
I made an inclusion in S2 mode with S2 authentication from pin on the device, then the device was enrolled correctly.
But the the interview step is broken. From ZwaveJs2Mqtt console logs:
2022-01-14 13:29:42.037 INFO ZWAVE: Zwave driver is ready
2022-01-14 13:29:42.039 INFO ZWAVE: Controller status: Driver ready
2022-01-14 13:29:42.064 DEBUG ZWAVE: Binding to node 1 events
2022-01-14 13:29:42.064 DEBUG ZWAVE: Node 1 has been added to nodes array
2022-01-14 13:29:42.065 DEBUG ZWAVE: Binding to node 6 events
2022-01-14 13:29:42.065 DEBUG ZWAVE: Node 6 has been added to nodes array
2022-01-14 13:29:42.067 INFO ZWAVE: Scanning network with homeid: 0xd867d5e3
2022-01-14 13:29:42.068 INFO ZWAVE: Node 1 is alive
2022-01-14 13:29:42.074 INFO ZWAVE: Node 1 ready: Silicon Labs - ZST10-700 (700 Series-based Controller)
2022-01-14 13:29:42.126 INFO ZWAVE-SERVER: ZwaveJS server listening on 0.0.0.0:3000
2022-01-14 13:29:42.152 INFO ZWAVE: Node 6 is alive
2022-01-14 13:29:42.290 INFO ZWAVE: Node 6: value added: 114-0-manufacturerId => 271
2022-01-14 13:29:42.291 INFO ZWAVE: Node 6: value added: 114-0-productType => 1282
2022-01-14 13:29:42.292 INFO ZWAVE: Node 6: value added: 114-0-productId => 4096
2022-01-14 13:29:42.420 INFO ZWAVE: Node 6: value added: 134-0-libraryType => 3
2022-01-14 13:29:42.422 INFO ZWAVE: Node 6: value added: 134-0-protocolVersion => 6.2
2022-01-14 13:29:42.423 INFO ZWAVE: Node 6: value added: 134-0-firmwareVersions => 5.2
2022-01-14 13:29:42.423 INFO ZWAVE: Node 6: value added: 134-0-hardwareVersion => 2
2022-01-14 13:29:43.650 INFO ZWAVE: Next update scheduled for: Sat Jan 15 2022 00:00:00 GMT+0000 (Coordinated Universal Time)
2022-01-14 13:30:44.080 ERROR ZWAVE: Interview of node 6 has failed: Attempt 1/5 failed
2022-01-14 13:31:09.644 ERROR ZWAVE: Interview of node 6 has failed: Attempt 2/5 failed
2022-01-14 13:31:29.886 ERROR ZWAVE: Interview of node 6 has failed: Attempt 3/5 failed
2022-01-14 13:31:55.441 ERROR ZWAVE: Interview of node 6 has failed: Attempt 4/5 failed
2022-01-14 13:32:35.863 ERROR ZWAVE: Interview of node 6 has failed: Maximum interview attempts reached
I'm trying with and without sensor connected to the device with the same wrong result.
Who is any idea about this issue ?
Thanks!
Gil
