Heat Controller cant update to 4.9
fingusio
Cant update to 4.9 , any idea?
/monthly_2022_01/image.png.e3f760891833a0396a0bf2164bf31071.png" />
Edited by fingusio
You should have battery level at >60%. I had this issue. After charging went update went smooth
  • From 4.5 -> 4.9 update OK even battery same as other
    From 4.7 -> 4.9 not work, later will charge and lets see
  • must reconfigure device to remove security?
    Edited by fingusio
    @fingusio
    I dunno I think you have to remove and add again without S2 security, but I'm not sure. Maybe sombody else can confirm.
    That's the reason I don't use S2 security, because I see some people struggling with S2 security and updates.
    Edited by Flash
    I've been able to update 2 devices so far 4.7 -> 4.9.  However, I had to move the controller quite close to each valve (within a couple of meters), otherwise I was getting failures.  Also,  I noticed devices updated, and those failed, default to 20C.
    Edit:  All  devices now updated.
    Edited by Methley
