Jamie 0
I am using the input to link to our alarm system that has a magnetic contact for the garage door. The idea been that I can work out if the door is open or not using this sensor. I assumed I would just be able to extend the circuit using implant as everything is normally closed by default. Everything tests ok, but the alarm system show an error, I believe its because the alarm system has voltage monitoring and is expecting 5v, the implant seems to be giving out 12v and thus throws the alarm into a error as it sees a voltage change, together it seems to be nearly 7 volts.. Anyone come across this? I would prefer not to have to run another sensor for the door.
Jamie
13 answers to this question
