In device view, I can no longer see the headline for each Parameter. It just says Parameter 1. If I click and expand on it, it shows correct info. That means I have to expand each parameter to see which one I need to edit.
You may have accidentally unchecked "Use template for parameters"?
But note that not all devices have a template.
Edited by RH_Dreambox
    17 minutes ago, m.haczyk said:
    Are you using Z-Wave 3.0 BETA?
    Yes, I am.
    I don't have that tickbox available. Might be because I'm using ZW3 engine?
    Yes, it can be so. Z-wave 3 is in an early beta stage and lacks a lot of features.
    I have the same issue with the ZW3 engine.
    Bigger problem for me is that I can not add custom parameters when no template is avalible:
    anyone knows if the upload template feature is allready working and how you should define a parameter in the .json file?
    {"description":"","parameters":[]}
    You can download template from other device as a source.
    Hi Roszak,
    I tried. Downloaded the template of a Fibaro Dimmer 2. But they are empty they only show.
    *Edit
    I had to choose the wright child device to have the .json file ?
    Edited by 10i-
