I am having a lot of problems with the latest Apple app update and the RGBW442 Leds.
Since this last update in Apple App the dimming has stopped working. You try to change it but it doesn't react, from the PC it works perfectly and from Alexa too.
On the other hand, there is a problem in the app every time you try to set the color only white #000000. Every time I press the color from the app, the led turns off, and it is only possible to operate it from the PC or from a scene.
Can you check it? The first one is very important as I can't dim any led at the moment.
thank you for your comment.
We know about it - fix will be prepared.
