Spiky 2
Hi to the forum,
I face a problem, which came up using the new Roller Shutter 3 device.
Situation: In the past I used two Roller Shutter 2 to drive two roller blinds (window, door). To simplify the handling I set up an association from the door roller shutter to the window roller shutter. This worked very good over years.
Now I had to change the Roller Shutter 2 device of the window into Roller Shutter 3 device.
Problem: The new arranged association between Roller Shutter 2 (door) und Roller Shutter 3 (window) does not work although it works vice versa (RS3 --> RS2). My investigations result the Roller Shutter 2 supports single channel association while the Roller Shutter 2 suports multi channel association. All efforts to make it work were unsuccessful.
Can anybody help me?
Spiky
