Bug: IN1 and IN2 from smart implant don't work with ZW3 engine
When I configure IN1 and IN2 on the Smart implant as NO Binary sensors they don't work.
I have two devices both have the same problem.
They worked with the ZW2 engine
Thanks for the report, we will check it out.
Guest Rafal_ll
I have exactly the same error
We know what is the problem (reproduced), task in backlog and this will be fixed in next beta version of the firmware.
    Should this be fixed with the 5.100.22 update. It still doesn't work so probably not?
    Nope, there wasn't time to do this to GA version.
    Next beta will resolve this one.
    Does the Binary sensor has this same problem?
    Can't see any response form the inputs either.
    Temperature's from this device are coming back correctly.
    Old UBS is not officialy supported yet, I will check it out and get back to you about this one.
    • 1 month later...
    Inputs of the smart implant are still not working. Should it be fixed with the new Beta?
    Yes, in 5.102 :)
    Do you have an date for the release of 5.102?
    It should be released this week.
    It's working. Thx
    I am glad it is resolved.
    • 2 years later...
    in my experience, if I install it in S2 mode, Binary Sensor mode still doesn't work
    • 11 months later...
    Is this issue resolved? I have UBS and try to connect analog input 0-10V, but UBS does not show any change of voltage. If I check with voltmeter, sensor definitely changes voltage. It continuously display 0V. I made parameter 20 visible and set it to 4, and adjusted parameter 63.
    I have HC3 with latest firmware and ZW3. Any ideas?
