Bug: Temperature sensor of thermostat not avalible on ZW3
I have a Qubino PWM Flush thermostat it is recognized as HVAC thermostat.
Only it doesn't show the temperature sensor it self, so you do not know the actual temperature.
With the ZW2 engine the temperature sensor was avalible.
Probably device does something not fully protocol compliant.
Could you PM me logs dump after inclusion? It will help pinpoint what causing it.
which one is it, the v1 or v2 (ZMNKID1
    It’s the Flush PWM I think there is only one version ZMNHLD1.
    They don’t make PWM version anymore. Should be similar to the on/off v1
    Edited by 10i-
    Unfortunately it is an issue with the module and implementation of CC Multilevel Sensor - device does not report supported scales for temperature (the frame is empty).
    Device will need custom implementation to work correctly with ZW3.0.
