See that I don`t get any energy consumptions grafs anymore after upgrade in the main display. The graphs stopped working at the same time as upgrade.
Seems to be the usage does not add up, but the units is there with usage.
Please contact support ASAP, we would like to take a look.
You can also PM me directly if you prefer.
Yes, i have the same problem, after downgrade all ok...
The same issue here. I have a Qubino 3-Phase Smart Meter between the grid and my house, this is setup in the Main energy meters: filed.
Setup of Energy consumption is:
  • Save energy to database = checked
  • Use stored energy data in Energy Panel = checked
After upgrade also:
  • Production:0.00 kWh
  • Consumption:0.00 kWh
And the last issue: I am missing possibility to chose Main energy meter for Production.
One positive change: After upgrade, consumption in the Yubii mobile app is shown correctly.
This is that way.
Normally you have one, maybe 2-3 devices which reports production - this is automatically summed up to production part for the panel.
In case you have readings which overlaps just disable Use stored energy data in Energy Panel  for not needed production device.
The rest - we are working on it.
We got a fix for it.
If someone want to test it before the official release just PM and we will arrange the rest there.
Michał
