Just got two Qubino Smart Meters installed, 1 phase and 3 phase.
3 phase seems to work fine, but the 1 phase gives me a Error 500 when I try to enter Advanced og Parameters.
So I can`t hide QAs and make other adjustments.
It does read consumption.
1Ph meter is not officially supported but it should work ok even with generic support.
Are you using ZW2.0 or new ZW3.0 Beta engine?
    It was installed with ZW3 beta, since I do not have any other choice.
    It is important to get that working, since it is monitoring kWh usage for my tenant electric car charging.
    If not I have to remove it.
    One can click away the 500 popup,  params are not pulled so that's why the error is there.
    Btw, the error is on old ZMNHTD1 H1S6P1 (fw v6.7, none enc included) and latest  ZMNHTD1 H1S8P1 (fw v80.01 with S2 included).
    When you click it away on params tab and upload attached template, you will be able to set params and view/edit advanced page without any error.
    I haven't added all params, feel free to add / edit the template.
    So far is the latest hardware working with S2, the tricky part with changing relais ex/inclusion as well, sometimes addtional soft reconfig is necessary. The old hardware without S2 is bit more dirty, one must change params to enable switches, soft-reconfig, exclud/include and soft reconfig again.
    In case you don't see after soft reconfig params (which seems to happen if one enabled relais), check "show hidden", you wil see all meters twice and actually these hidden can accept attached template
    Edited by tinman
