Polling time interval cannot be updated any longer
In version 5.093.21 the Polling time interval on the "Gateway" tab cannot be updated any longer: each time you try to enter a new value, it always returns/overwrite it with the old initial value... :-(
quickly. just more quickly doing it.
Fibaro trying to check your performance :)
now i can achieve this after 2-3 attempts :D
@philv
It was the same problem in previous versions.
If you repeat the procedure many times (10 times or more), you can change the value with a bit of luck, but you have to be quick to save before the value jumps back.
    Thank for your answers. This should be fixed by Fibaro as it is a *** real bug ***.
