QApp Fronius + panel Energie Hc3
I have an installation of Fronius and Fibaro HC3 solar panels.
I have installed the quickapp fronius which can be found on fibaro marketplace, it works fine with a small modification of the code so that the production is displayed correctly in the Energy panel.
Now I am facing another problem, during the night the consumption is well recorded on the panel, but as soon as the solar production starts the consumption stops counting because the production is higher than the consumption.
Has anyone had this problem or knows how to solve it?
That is normal behaviour. The production of your solar panels first goes in to your consumption. In your Fronius QuickApp you will see the actual production.
