I am creating several scenes to introduce a new alarm in my system. The idea is to activate it through "The Button" (e.g. 1 push activate alarm, 2 times, disarmt it). But i would like to know if there is any open window when I activate my alarm. By now, I have created an scene with all my sensors, indicating that if there is ANY of them opened, the system push me a notification indicating that a window is opened. It works BUT only when the window chage its status, I mean, if i open a window, the notification arrives but if the window remains opened, it doesn't. How can I do it?
Thanks!
What gateway are you on?
    Sorry, HC3.
    You could check the status before arming the alarm. Is that what your aim is?
    Hm, my idea is: I arm the alarm and, if by mistake, one of the windows is opened, I receive a notification to go and close it.
    You could check the sensors and send a notification when a door / window is open and give a choice to arm or not yet arm the alarm.
    Here is a simple script the check some sensors, if they are open. In the end of this scene you know if one ore more sensors are open, so there is the moment to decide to arm or not to arm.
    (You could make it better, more flexible, but it is a start)
    :D
    Thanks. As you might now by now, I am really new on this. How can I fit this into Fibaro?
    If you look at Event Runner it will have the options you want/like.
    If you want I cab send a part of my arming scene where I get notification if door/window is open
    //Sjakie
    A small example how it looks like
    I didn't noticed. Maybe look at other solutions to get it working like:
    EDIT: same thought as @Sjakie :-)
    Edited by SmartHomeEddy
    read for appPhone your button!
    Thanks!!
    Sorry, what do you mean? :)
    Note; You need to set a delay for arming or if a door/window is open to cancel arming.
    If you like it I can send my "old"QA to you. Than you have a more complete picture/ understanding of this materie
    //Sjakie
    //Sjakie
    That would be a high step for me, thanks in advance!
