No issues updating.
Again. Nice flow of updates coming from Fibaro.
Great to hear that, we put much more attention for stability from some time now and we want to continue this trend.
Guest kallecux
Here also everything OK!
Any updates still comimg to the HC2 ?
Yubii with 40 zwave devices seems to be busy doing strane things
HC3 (empty .. no QAs, no zwave, no zigbee, no nice/elero)
second HC3 with shitload of things shows some high load (as always on this HC3 due to things running there) plus these spikes as above.
that "error" seems to be pure visual thing, no high load in logs, htop shows almost no load, Yubii in Edge (bottom) and Chrom (top), exact the same time comparision
/monthly_2022_02/image.png.472e43f964af88f35c0d40836d9e1694.png" />
clear cache / cookies not really solving it, seems to come back after some time when diag tab is open. Sometimes Edge is better, sometime Firefox or Chrome.
Anyway, as all my HCs reacting still fast (or as they did before update), and i don't see any lag, i would say diag tab issue. Tested with two different laptops, so not graphic driver issue.
Edited by tinman
Update yesterday, looks good so far.
System use to restart every 6-10 days hopefully that is gone now.
Yep, one in progress right now :)
Update today and went smoothly.  Thank you Fibaro.
My system: HC3 master with 1 HC3 slave and 7 HC3L slaves.
  • 2 months later...
In which quarter of 2022 will the new version for the HC2 be released?
I can assure that current one... :)
