LUA: Condition to trigger changes of any device? (off all devices)
I use a scene that transmits changes of any value of all devices. I use at the moment the following condition (and ist works)
 the three points in the center stands for all other devices.
Now I have to adopt the scene with every device I add to my network.
Is there a possibility to trigger to all devices in one block?
Like this:
The "ID = 000" should stand for any device?
Is such a condition possible?
Thanks for hints
Oliver
5 answers to this question
lol
unfortunately you can't use wildcard or "anyvalue" abbr for handling events from any devices.
it's not possible. it's designed by Fibaro devs
alas
    Tanks for the answer. That's a real pity. That would be a very powerful function.
    I wonder, how the app developer solve the problem to react very fast on a change of e.g. a switch status? I think it is not the best solution to poll every second the status of all devices?
    best regards
    best regards
    We typically call /refreshStates for the current HC3 events.
    If  there are no events the call hangs so it  doesn't  take cpu and when it returns events we use some sort of hashtable lookup to decide if it was an event we were interested in. Probably as fast reaction as you can get... Probably not a big difference from the underlying scene mechanism that invokes scenes....
    jgab@ thanks for the answer.
    Can you give me please a hint how you call the refreshStates from the HC3? That can not work with the REST-API, except you poll in a high frequency.
    --Oh, I saw you wrote a QA "EventRunner4". Do you mean, that this QA is calling the refreshStates and not a other device like a SmartPhone-App.  I think I misunderstood this. I guess, that you QA EventRunner4 is not working on a HC3L?
    On the other hand the smartphone -Apps can react very fast on events without a special program on the HomeCenter.
    Edited by cervicor
    The smartphone app is supported by the whole FW on the  HomeCenter + Fibaro's servers...
    the refreshStates api react as soon asa there is an event. If you call /refreshStates and there is no events it will hang until there are events.
    So the poll  frequency depends on the frequency of events on the HC.
    For an code example look at
