Hi All, @m.roszak,
Look like Energy Panel don't calculate energy consumption by different tariffs - in my case it day ( 07-23 ) and night ( 23-07 )
all calculation made by main tariff, but it shows differentiation
 by day / night at the bottom of settings page
Example:
today I consume 107 kWh and Energy Panel shows that I spent 204 UAH - it give us 1.90 UAH per kWh - means, that Panel calculate all energy by Day tariff.
My own QA calculate that 50 kWh consumed by night, 57 by day tariff, so - data is very different
Thanks for the report. We had one report before that something is wrong here - we performed again all test and everything worked ok.
We will again look into it.
If we won't be able to reproduce we would like to take a closer look at your configuration - let me know if this won't be a problem.
Michał
    Michał
    Yes, sure, I'm ready to help :)
    PM me, if needed a session
    I had the same issue.
    What worked for me, was to add cheap night tariff as base one (Main rate), and then add day tariff as additional rate.
    Now it looks like the calculations are correct.
    Edited by AndrewD
    Thanks, will try it
