Alexa TTs on Fire Tv Cube
Guest Benrive
Guest Benrive
I am trying to use TTS on a Fire Tv cube, but a send a command for ip to alexa cube and alexa does not receive them.
It tells me connection refused.
Do you know if it is possible to use this device?
5 answers to this question
Well, if you ask me. TTS works with alexa. But you don't send the commands to the device itself.
You need a script or some other way to send a TTS command through the amazon servers.
Could you explain a little more what you are trying to do ?
Guest Benrive
    Hello @ppeterr,
    I would like from all in one AOQ to use its TTS function.  I have everything set up but I can't get my Alexa fire tv cube to play anything.  I have also tried with Voice Monkey installed on Alexa.  but even the triger that is shown does not work.  More tests, with IFFT the same.  I don't play anything.  AOQ sends a line to the fixed IP and port 8080 of my Alexa.  but the connection is refused.  I really don't know what else to try
    8 hours ago, Benrive said:
    Hello @ppeterr,
    Oke, i dont know much about the All-In-One quickapp. I think you might get an answer if you
    post in that topic itself about your problem.
    I am using a different method.
    In short, this script runs on a secundairy device (like a NAS(docker) or RPi, or anything that can
    run a small webserver. If you want to go that road. I can help you.
    Edited by ppeterr
    Guest Benrive
  • 28 minutes ago, ppeterr said:
    Oke, i dont know much about the All-In-One quicakapp. I think you might get an answer if you
    I have a Synology NAS, but it's old and can't run docker. I'll try with a RPI3, and if I have doubts I'll ask you. Because no other method allows me to run TTS.
    Sure, just to get you started.
    - install LAMP
    - Be sure to have the JQ package also installed.
    - Get the refresh token
    - Edit the alexa_remote_control.sh script with your info and that token
    Test the script on the CLI
    ../alexa_remote_control.sh -e speak:'This is a test'
    If this works, your almost there :)
