Nuki QA stops working after firmware update
Today I update from 5.90.17 to 5.100.22. This get very wel and hope the spontaneous stops.
Unfortunately I see that the Nuki QA (Fibaro marketplace) is not connecting to Nuki Api. Worse, the forum member who build this QA no longer provides support:-(
What has Fibaro changed in their underlying code that makes this no longer work.
Other forum members with the same issue / solution?
Nuki response time on API is bit tricky sometimes, i had to fix things as well for that QuickApp
The reason is actually the socket/http (one connection at time) on Nuki side, which has been changed as well from Fibaro side in GA100.
    Thanks for you quick response.
    I have use the Nuki 2.0 AND 3.0 lock and works both perfect with the QA from the Fibaro Marketplace, till now:-)
    No problem to pay for this QA, but the new Nuki 3.0 has no Bridge, but build inside Wifi.
    Will this QA works with Nuki 3.0 (API token)
    only the Pro version, which is actually not really available
    i updated the QA to latest available API, so yes. Of course can't test with Nuki 3 Pro, because availibility situation, however the API speak about 3.0 and 3.0 Pro, so it should work
    • 3 months later...
    this links dosen't seems to be working
    is this still available ?
    yes it is, link fixed ...
    Edited by tinman
    I delete my question...
    Everything is good
    Edited by Bloug
    • 3 months later...
    hello,
    @tinman sorry but link for NUKI QA update seems not available anymore.
    thx in advance
    yes, we took our quickapp.info website offline, we will move to new Fibaro marketplace (when it does online), for now contact we via PM
