HTTP in HC3 scene
can anyone please advise me? I need to send the command "http://192.168.10.88:8765/?doorbell=show" to the scene in lua in HC3, just like I would type it into web browsers and enter.
I write like this, but it doesn't work for me, resp. does not overwrite "? doorbell = show"
when I sent from fibaro, I get an answer:
Hello, World
Header
content-length : 4 remote-addr : 192.168.10.6 http-client-ip : 192.168.10.6 host : 192.168.10.88:8765 content-type : application/json cache-control : no-cache accept : application/json user-agent : Boost.Beast/306
method = GET
uri = /
Params
NanoHttpd.QUERY_STRING : null
when I sent from web browser, I get an answer:
Hello, World
Header
referer : http://192.168.10.88:8765/?doorbell remote-addr : 192.168.10.50 http-client-ip : 192.168.10.50 accept-language : cs-CZ,cs;q=0.9,en;q=0.8,sk;q=0.7 host : 192.168.10.88:8765 upgrade-insecure-requests : 1 connection : keep-alive accept-encoding : gzip, deflate user-agent : Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/97.0.4692.71 Safari/537.36 accept : text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9
method = GET
uri = /
Params
doorbell : show
NanoHttpd.QUERY_STRING : doorbell=show
Can anyone please help me and fix lua in the scene?
Thank you
11 answers to this question
You asking json instead of expected (as I can see) xml
and more than you pass json in the body in GET method it’s really LoL ;)
    @10dercan you please advise me how it should be spelled correctly.
    I copied the code from another manual, but you can see that it is wrong.
    Thank you
    Hi @michal_pu
    I think with this example, you will get started
    Hi @SmartHomeEddy
    thank you for the sent example, but i don't know how to use it in the scene. If it didn't bother you much, could you help me?
    IMHO
    remove
    also probably remove
    removed, according to the instructions. Actual code:
    Not working yet.
    Fibaro returns the answer:
    Hello, World
    Header
    content-length : 0 remote-addr : 192.168.10.6 http-client-ip : 192.168.10.6 host : 192.168.10.88:8765 cache-control : no-cache user-agent : Boost.Beast/306
    method = GET
    uri = /
    Params
    web browser, returns the answer:
    Hello, World
    Header
    method = GET
    uri = /
    Params
    doorbell : show
    I am sorry to bother you. @10der@SmartHomeEddy Please do you have a working solution?
    Hello.
    i faced a similar problem.
    Did you get a decision?
    here is my code.
    %% properties
    45 value
    %% events
    %% globals
    local sensor1 = 45
    local temp1
        temp1=fibaro.getValue(sensor1, "value")
    local url = 'http://192.168.23.211/awp/MyHome/set_1.html?%22DB_WEB%22.temp_1=11.1'
    --url=url..temp1
    local headers = {
            ["Accept"] = "application/json",
            ["Content-Type"] = 'application/json',
            ["Cache-Control"] = "no-cache"
    local selfhttp = net.HTTPClient({timeout=2000})
    selfhttp:request(url, {
        options={
            method = 'post',
            data = json.encode(body),
            headers = headers,
        success = function(response)
                print(response.status)
                print(response.data)
        end,
        error = function(message)
                print("error:", message)
    I transfer data to Siemens PLC
    Here is the answer
    [14.02.2022] [22:22:27] [DEBUG] [SCENE70]: My Title Outdoor temperature 0.4503021
    Bedroom temperature 20.7
    I receive data from plc
    no database entry plc
    @Dimshem I tried this procedure but it also doesn't work. The result is still the same
    encode query params please
    it too different with QA
    I don't understand your question.
    Please state differently.
    My code is written in scene.
    Is it possible to avoid QA?
    Sorry for my english, i use google translator.
    volume_up
    183 / 5 000
    Результаты перевода
    I don't understand your question. please state differently. please. my code is written in scene. Is it possible to avoid QA? sorry for my english, i use google translator.
    Edited by Dimshem
    I made a mistake
