Quick App calling a Scene?
I have a QA with infrared commands to turn on (ON) and turn off (OFF) a sound amplifier.... I need, when pressing the "ON" button, that in addition to sending the IR code, it also triggers a Scene, that is possible? Could someone please guide me better how to do it?
Thanks,
5 answers to this question
Just run the scene you need
fibaro.scene("execute", {<scendID>})
    cag014@,
    thank you very much for your attention, I got what I needed, very grateful.
    On 06/02/2022 at 00:37, cag014 said:
    Basta executar a cena que você precisa
    fibar . cena ( "executar" , { <scendID> } )
    how to trigger two scenes on the same button, and how to trigger another button? Would you help me?
    You can trigger many scenes in one command:
    fibaro.scene("execute", {<scendID>, <sceneID2>})
    For each button in QA you can define function, so in the function call the scenes
    For example
    imo this couples your QA and scene too much. Wouldn't it be better to to raise an event from QA and use it as a trigger for scene? Then you do not need hardcoded scene IDs and change QA code when more scenes are created.
