need Help, Lua Coding HC3
i just moved vrom HC2 to HC3. I like the new HC3 but i have problems with the new LUA coding. I just don't get it at all. I'm used to programm in C++ and also programmed some scenes in the "old" LUA. But now i'm lost.
My problem ist actually simple. I have for example 2 or more motion sensors and one or more switches to have an action on. The light should only come one between 10pm and 8am. Either motion sensor can actuate the light. I tried with block scenes too, but also no success. Maybee i have some big tomatoes on my eyes and i just don't see it.
that's what i tried...
I'm looking forward for any help! Thanks
Best regards Hans
    conditions = { {
            type = "device",
            id = 284,               --motion Eye1
            property = "value",
            operator = "==",
            value = true,
            isTrigger = true
            type = "device",
            id = 72,                 --motion Eye2
            property = "value",
            operator = "==",
            value = true,
            isTrigger = true
            conditions = { {
                    isTrigger = false,
                    type = "date",
                    property = "cron",
                    operator = "match>=",
                    value = { "00""22""*""*""*""*" }
                    isTrigger = false,
                    type = "date",
                    property = "cron",
                    operator = "match<",
                    value = { "00""07""*""*""*""*" }
                operator = "all"
            operator = "any"
4 answers to this question
I think the problem that you set operator="all" for time condition. The time can not be greater than 22:00 and less 07:00 at the same time.
Try operator="any" for time conditions also.
To avoid all that I strongly suggest to use
    Hello, thanks for your suggestions. For the operator conditions i tried every possible combination. Even with the timespan on the same day (from 21:00 to 22:00). Nothing worked. Then i tried to look at the two motion sensors seperate, but it didn't help either. I will read the AOQ's and the other files, some of them i read already thow... In my old HC2 i did setup the same situation and it worked for years. And i didn't wanted to transfer the system from HC2 to HC3 becaus it gave me the opportunity to a fresh start. The whole house is now converted to HC3 exept the situation in the Hall and Staitcases with the Motion lights. I have to grow into this new Lua coding. At first i didn't have a clue but now i see it a bit clearer. But i have to say that C++ is a dream to programm compared to this Lua....
    There is nothing wrong coding with Lua, but Fibaro conditions and other their built-in high-level commands create problems to the users.
