Errors when a HC2 scene starts a scene in another HC2
I want to start a HC2 scene from another HC2, but something is going wrong, I've no idea what.
Perhaps a missing parameter?
Who can help?
1. Try:
  dat= json.encode({args={16,18,19,22}})
  datLen= tostring(#dat)
  print(dat, datLen)
  http= net.HTTPClient()
  http:request("http://192.168.2.38:80/api/scenes/218/action/start",
  { options= { headers= { ['Authorization'] = "Basic abc...xyz=",
                          ['Content-Type'] = "application/json",
                          ['Connection']= "close",
               data= dat,
               method= 'POST',
               timeout= 5000
    success= function(resp)
      print("resp.status:", resp.status, "C-Len:", resp.headers["Content-Length"])
    end,
    error= function(err) print("Err:", err) end
Result:
[DEBUG] 22:49:43: {"args":[16,18,19,22]} 22
[DEBUG] 22:49:43: 2022-02-06 22:49:43.325015 [ debug] error reading from socket: End of file
[DEBUG] 22:49:43:
[DEBUG] 22:49:43: Err: End of file
Great surprise: data are sent !
with   ['Connection']= "Keep-Alive"    instead of   ..."close":
[DEBUG] 00:51:02: {"args":[16,18,19,22]} 22
[DEBUG] 00:51:05: 2022-02-07 00:51:05.112165 [ debug] Detected chunk with zero size, terminating connection
[DEBUG] 00:51:05:
[DEBUG] 00:51:05: resp.status: 200 C-Len: nil
  print(json.encode(resp))  shows:
[DEBUG] 00:51:05: {"data":"","status":200,"headers":{"Cache-Control":"no-cache, no-
store","Transfer-Encoding":"chunked","Server":"nginx\/1.8.0","Content-Type":"application\/json;charset=UTF-8",
"Date":"Sun, 06 Feb 2022 23:51:05 GMT","Connection":"keep-alive"}
data are sent here too!
2. Try with added line:    ['Content-Length'] = datLen,
Result:
[DEBUG] 22:54:09: {"args":[16,18,19,22]} 22
[DEBUG] 22:54:09: resp.status: 400 C-Len: 172
no data sent
with  ['Connection']= "Keep-Alive"  instead of ..."close"  also no data sent
Thanks in advance!
Please check if your Authorization is correct and the user has permissions to run that scene.
in addition I am using these headers and it works just fine
headers={ ["Content-Type"]="application/json;charset=UTF-8",
                                    ["Accept"]="application/json",
                                    ["Authorization"]="Basic vvbnjjknm....."}},
Edited by cag014
    Hello cag014,
    thank you for your answer.
    Authorization is correct, user has permission to run that scene,
    so I added     ;charset=...
    and    ["Accept"]=...
    but nothing changed. (data is received!)
    Your sending scene doesn't write something like this ?
    [DEBUG] 14:32:07: 2022-02-08 14:32:07.725228 [ debug] error reading from socket: End of file
    [DEBUG] 14:32:07:
    [DEBUG] 14:32:07: Err: End of file
    or when   ['Connection'] = "Keep-Alive"   is added  like this ?
    [DEBUG] 14:36:26: 2022-02-08 14:36:26.459030 [ debug] Detected chunk with zero size, terminating connection
    [DEBUG] 14:36:26:
    Is in your receiving scene a command to 'answer' something for the sending scene to have some 'data' to read ?
    Thanks!
    Hello cag014,
    one more question:
    there is no need of   ['Content-Length']=  ?
