Unresolved issues
marlo
I updated the HC3 (at 5.100.22) and the heads (at 4.9) in the expectation that the synchronization and display temperature problems would be fixed, but disappointing again. In plan is set the temperature to 22 ° C, but the head is 19 ° C. When I let it sync so it goes OFF and back to 19 ° C WTF why? Another problem is when I set the temperature on the head manually, so after this time the head goes OFF. When I do it in the plan, it immediately goes OFF. Fibaro Heat Activator works probably well, but it regularly happens that the temperature is set at 22 ° C, the room temperature is 23.5 ° C, but the head sends a request for heating and the radiator is hot. Another problem is that sometimes the head in HC3 shows that it is OFF but actually set to the desired temperature in the plan. When I put my head OFF so it regularly happens that even when OFF it sends a request for heating. I'm starting to despair.
I have described all this in this thread and I am not alone in having such problems:
Are you sure that device is assigned to climate zone?
You can try removing it and adding it again to desired zone if it will look like it is.
    I've already done that. I deleted the climate zone and created a new one
