[lua quickApp HC3] response body truncated with HTTP request
In some case the response body is truncated when calling HTTP request
With curl:
Response body:
With lua:
Response body:
The strange behavior is :
  • When the response.status is 200, the response body is complete.
  • The problem occurs only with all googleapis
Is it a bug of the library ?
The full headers are
Yep, it's a bug. If  you make the same call from a scene you get the whole error  back.
I have never understod why they have different library implementations for QAs and Scenes...
    Thanks for the answer.
    Is there a bug tracker somewhere where I can explain this bug ? Or maybe Fibaro is already aware of this bug ?
    • 3 weeks later...
    Send it to support, they will add it if it not exists. I did this twice.
    Edited by Joep
