Push notification when motion is detected.
Guest swissnet3000
  conditions = { {
      id = 295,
      isTrigger = true,
      operator = "==",
      property = "value",
      type = "device",
      value = true
  operator = "any"
  conditions = { {
      id = 289,
      isTrigger = true,
      operator = "==",
      property = "value",
      type = "device",
      value = true
  operator = "any"
AKTION
local sensors = {295}
local debug = false
local delay = 0
function actionsMotion()
 print('Führe Aktionen bei Bewegungserkennung aus')
 fibaro.alert('push', {[1] = 2, }, 'Bewegung im Büro wurde erkannt !'false)
local sensors = {289}
local debug = false
local delay = 0
 fibaro.alert('push', {[1] = 2, }, 'Bewegung im Gästezimmer wurde erkannt !'false)
4 answers to this question
Why not make a blockscene?
And if you still want the Lua, you can convert it to Lua.
Perhaps a tip.
Create scene in blocks and convert in lua than you will see your missing part
//Sjakie
ships I am getting to slow!
Guest swissnet3000
    I did, but when a sensor is triggered, I always get the push message from both rooms. But if the sensor in the office is triggered, I would like to receive a message only from the office. And one from the guest room when the sensor is triggered there receive a message from the guest room. Block scene is only possible if I make two single ones, with LUA I would have one scene because HC3L is limited
    Maybe look for solutions like:
    or
