The Z-Wave Configuration screen is flickering when a Slave is added to the system.
Haven't seen it before, but now I have a HC3L as slave I can see the screen flicker.
It happens right after the labels:
Polling time interval
Set how often gateway will retrieve devices data
Everything below is bouncing regularly, seems like some label refresh causing an issue.
The browser I use is the latest Firefox.
It happens to me also.  I have 7 slaves (HC3 and HC3Ls).  Hope this screen will be fixed in the next update
    Yes that's the same I see.
    Thanks for the report :)
