Heat controller does not to update from 4.7 to 4.9
CVERNOOIJ
I have succesfully updated all my heat controllers from 4.7 to 4.9 accept for 1. what do i need to do to get the last one updated as it always shows failed?
Hello @CVERNOOIJ
What I experienced with an update is that my probe had an empty battery.
After replacing the battery of my probe and a soft config. of the TVR I could update.
What you could try.
Fully charge the TVR.
Do a soft config. and make sure, IF you have a probe the Probe's battery is at least above 80%.
The inclusion should by without S2 security, otherwise exclude and include again without security.
restart the HC.
Do a mesh reconfig of the device. ( is the device far from the HC bring it closer and do another mesh reconfig)
try update.
Good luck
