Wrong calculation in energy tracking by 1,000 time?
Correct me if I'm wrong please.
I notice that my energy usage report in Fibaro is way over the roof so I started checking how Fibaro calculate energy usage per device.  The attached screenshot sample shows one light that consume only 36 Watts (Watt, not KWatt).  From the usage graph, I can see that the device is turned on and off all day.  However, the TOTAL TODAY USAGE shows 88.65 KWh, which is impossible.  I think it should be 88.65Wh not KWh.  The system miscalculate by 1,000 times.
Is this a bug in the software?
We will check it out :)
@Poom What is your software version? Is it a gateway connection system?
    The latest firmware 5.100.  I use gateway connection system.
    I would ask to contact the FIBARO support team.
    We created a simple setup for both GC and single gateway (FIBARO Binary Switch). Here are the results:
    Slave and Master with simple ON/OFF scene every 5 min:
    Your number seems right. Mine is off the chart. @m.roszak please help check on this on my system.
    @Poom, please pm me and we arrange some debugging :)
    @m.roszakI pm you.  Please debug my system.
