bzhou 0
I've just installed an implant and hooked up a reed switch to IN1 (between yellow wire and blue wire). I've set the param 20 to 0 (IN1 to NC Alarm mode). However, regardless of the state of the reed switch, I'm not receiving any notifcation updates. Reinterviewing always shows a value of 0.
One thing I have noticed is that the voltage values are always reporting around 20V regardless of the reed switch position - should I expect these to go to 0V when the switch is closed? (I'm assuming while the IN1 reed switch is open, I should see some voltage, but if reed switch is closed, it should report 0V?)
If so, does this suggest there is an open circuit somewhere through the reed switch?
One other obversation is that setting param 20 to 1 (IN1 to NO Alarm mode) does not change the status of the notification - it still shows as 0 / safe. This is rather unexpected - I'd assume that switching between NC and NO should give me opposite states?
Thanks for any help!
Edited by bzhou3 answers to this question
