Scene won't wait for timer.
I have a scene that must run when a device is ON, and at 10:46.
The scene wil give my Nest thermostat the 19 degrees setpoint.
It works, but it wil not wait for 10:46, it runs inmediatly.
What is wrong with my code?
    Is nobody reading this section?
    it looks like you have converted bock scene to LUA.
    In this case when you run the scene manually it will be executed immediately by condition below  (you can remove that)
    or
    then
        fibaro:call(431, "setProperty", "ui.setpoint.value" , "19 °C");
    By the way since the scene should run constantly please remove from %%properties
    427 value
    In addition make sure to set "Run scene" to Automatic
    Edited by cag014
    Tnx cag014, that was the solution.
