Jorge R. Dal Dosso 0
I bought a FIBARO HC2 with many accessories in Germany in 2018…it worked fine here in Argentina for a few months, after making several updates and with problems in some of them, I reached a stable update.
After a week my motherboard was burned, with disappointment I put it aside...
Now in 2022, I got a replacement motherboard and it boots into recovery mode, at 50% partition check it stops and reboots.
I understand that from a certain version the HC2 does not need the memory stick….
Fibaro, could you provide me with an image of the FIBARO FIBARO HDD?
It would be the solution for many users with problems, we could also continue buying Fibaro accessories.
