Is it possible to change a Fibaro ID to a new login (=email address) and password.
Reason for asking is that I will change to another ISP/email provider, hence the email address which I presently use for my Fibaro ID will change.
If so, could you please point out which steps to take.
In the account settings, you can change your Fibaro ID. Haven’t tried it, but looks like that is the way to do it.
    Ok, thanks for this.
    still a bit puzzled, reading the fibaro FAQ on this:
    Yes, it is required.
    So I need to change both Fibaro ID and local super user (makes sense), but will I end up in a chicken-or-egg situation, e.g. when I start with changing the Fibaro ID, can I still login with the “old” local login in order to change the local account (or vice-versa)
    • 3 months later...
    This is definitely a problem for me too.
    I can see that I can change username/email and password on the Fibaro ID but for the property login I can't find anywhere to change the email address - ideas welcome please?!
    • 2 years later...
    Guest Ericj
    I have the same problem, somehow it seems impossible to change the emailaddress of the admin/owner.
    Anyone?
    In the settings - access you can transfer the admin role to another user. What if you add a new user with that new email address and you transfer the admin role to the new user?
    (Never tried it myself)
    The steps, if I remember correctly, are as follows: First, add the account to which you are going to transfer the administrator permissions. Once you add the account and transfer the administrator role to it, you have to log in with the other account and accept the administrator role that will appear as a notification. (That's what I remember, it may be around that area of the screen).
    Now after having done the previous steps, you must unlink your HC3 from the old Fibaro-ID and link it to the new fibaro-id account.
