Turn ON the light when the door sensor state is OPEN.
I created a scenario very basic and it should be that way but unfortunately I can't make it work. What am I doing wrong? I created the scenario but without the LUA because I am not familiar with coding. I gave a try though by copy/pasting what's in the forum and edited the ID's etc... but no sucess!. Please please help
I gues the light stays on?
You alse need to create scene if window is closed.
You can look in this forum for Event Runner coding will be easier as in LUA you create around 5-6 QA's for whole home
Succes
//Sjakie
    Thanks for the reply. Actually it doesn't even Turn ON the light. If I hit "play" though in the creation of  a scenario it turns the light ON. I am really confused :(
    If you push in scene play/activate it will overrule everything thts why its working.
    My advice create also window sensor closed>> light out and try again.
    Succes
    //Sjakie
