Hello there
May I ask some expereinced developer to give me a hint.
If my QA variable should be in a certain format,  ex. time format ("22:00"), what is the best way to control it, and not allow user to insert inapropriate format and notify him by some error message?
Is it even possible?
Thanks a lot for any help
Edited by Neo Andersson
If it actally is the aim to input a time, there is a way to use QA buttons to insert the right time.
    Button ? For QA variable ? Sorry, i dont understand, What button?
    You mean create a UI button for this?
    No i dont want to use extra UI elements. I need to check the inserted value in the textbox on the picture
    Yes, that was what I meant. If you don’t want to use the UI, that is ok. But is is a way to get the right values.
    Anyway, big thank for your help
    I don’t prevent wrong entry, but still try to make something out of it, upper or lower case, the right decimal character, etc. And if that doesn’t work, I ruthlessly ? use a default value as stated in the manual of the Quickapp ?
