Hello, I need help with a LUA script in a scene.
The following is planned:
Temp.sensors 3 = S1, S2, S3
Actor 1 = A1
if S1 > S2 then switch on A1, wait 10 min then if S3 < S2 then switch A1 off otherwise check S3<S2 again after 10 min
if A1 off then S1>S2 would have to be checked again.
Thank you in advance.
    if (fibaro.getValue(201, ‚value‘) < fibaro.getValue(77, ‚value‘)) then
    fibaro.call(47, ‚turnOn‘) end
    fibaro.sleep(math.random(10000))
    if (fibaro.getValue(76, ‚value‘) < fibaro.getValue(77, ‚value‘)) then
    fibaro.call(47, ‚turnOff‘) end
    After that my scene stops how can these if loops be looped over and over again?
    You could use interval in your trigger. Look here for the manual:
    (or use a quickapp)
    Scene dont start again
      conditions = { {
          isTrigger = true,
          operator = "matchInterval",
          property = "cron",
          type = "date",
          value = {
            date = { "00""10""5""3""*""2022" },
            interval = 10
      operator = "all"
    This is the Example:
    Condition true every 10 minutes, starting at 12:00 5.04.2019
    1
    2
    3
    4
    5
    6
    7
    8
    9
    10
        type = "date",
        property = "cron",
        value = {
            date = { "0", "12", "5", "4", "*", "2019" },
            interval = 600
        isTrigger = true
    So if you want an interval of 10 minutes, in seconds it is 600
    If you copy-paste this one, it should work
    Sorry  but  its dont start again.   If I use only aktion  " fibaro.call  TurnOn" its run
    But you want it to start every 10 minutes, not 10 seconds?
    This was a 10 second test to see if it worked. In the live run it will probably be 10 or 20 minutes
    10 seconds trigger to run and a 10 minutes sleep, I don’t know if that will work
    I copied everything again into a new scene and now it works. Thanks for the help.
