HC3 Slat-Controll of venetian blinds in multiple device block scene
Dear colleagues!
I use a hc3 with the newst firmware and created a block scene. I want to close the venetian blinds and set the slats also to "close".
If I do with a single event with ONE device the option slat-open/close-position (in german "Lamellen einstellen" is selectable. But in group-devices (more than one venetian blind) the slat-open/close-position is not visible/selectable.
Here, in the single-device-setting the slat-position-option (in german "Lamellen einstellen") is visible/selectable:
Below, in group-option the "slat-position-option" (German "Lamellen einstellen") is missing/not showing:
Do you have a solution for me? I have about 18 Venetian blinds, so it would be horrible to do 18-times-single-device settings in one scene. And I can't use Lua scenes cause of controlling also via Alexa.
Would be very glad for your help/advice. Thank you!
Alex
I never have experienced something like this, however my first guess would be, that some of your shutters does not have the correct type selected. This is my guess. All should be set to venetian blinds with positioning.
    They are all configured the same. And even if I only select ONE Venetian blind in the group selection, the option "Lamellen einstellen" is not visible, but it is visible in the SINGLE device setting in the same scene. This has to be a bug. Maybe someone can verify this in his hc3?
    Until some Fibaro support confirms that this is a bug, i think you can use LUA code for this.
    Just put all the device IDs into curly brackets, and thats it.
    Thanks for this advice. I already have such a LUA-Scene, but Alexa can't handle LUA-Scripts. Thats the reason why I wanted to create the block-scene. But I am not willing to add 18 times a single device command. :)
