Two homes with Google Home and two Fibaro units
Lars-Even
I have a HC3 at home and a HC3Lite at my cabin, both connected to my Fibaro account.
In both places I have installed Google units, mini, Wifi and so on for Voice commands.
I have a problem now, with setting up the homes in Google Home.
When syncing the Fibaro units, I only get units from one of the Fibaro units into Google.
Do any of you have a solution for how I can get both homes, with the correct units synced into Google Home?
Best regards,
Lars
Edited by Lars-Even
Right now you don't have solution, we got on roadmap that function (right now you must manually choose which one you wanted to use with integration)
Only workaround but in your case not best is import devices from HC3L to HC3 with gateway connection - but that is a lot of work
  • Thank you for the quick response.
    Can you share anything regarding timing?
    Is it relatively close in the roadmap?
    Is it a function that could be available within some months? Half a year? More?
    Thank you in advance.
    Best regards,
    Lars
